Modlist: Airbog's toy
Airbog
Post by Airbog »
Stock (manufacturer info):
169 Hp at 6400 rpm
224 Nm at 4000 rpm
Horsepower per liter: 93.4 Hp/l
I level (firstsetup - before main part of these mods) (@ 0.95 bar):
271 Hp at 6750 rpm (+60%)
295 Nm at 6350 rpm (+32%)
Horsepower per liter: 149.3 Hp/l
II level:
400+ Hp - DONE & dyno tested
III level:
8000+ rpm and more power - DONE & dyno tested
MODS:
Engine:
- Greddy forged pistons (kaltiniai stumokliai)
- Greddy connecting rods (shvaistikliai)
- Greddy head metal gasket (metaline galvos tarpine)
- Tomei superstrong timing belt (paskirstymo dirzas)
- ARP head studs (galvos varztai)
- hybrid turbo
- Custom tubular top mount exhaust manifold (custom ishmetimo kolektorius su turbina montuojama virshuje, o ne i standartine vieta)
- TIAL wastegate
- GroundZerO cold air intake system using APEX'i air filter
- GroundZerO/DPR Europe intercooler piping (interkulerio vamzdziai)
- GroundZerO/DPR Europe ported/polished cylinder head (portinta ir poliruota variklio galvute)
- JUN camshafts
- JUN adjustable cam sprockets
- JUN titanium valve retainers
- JUN titanium valve springs
- TOMEI solid lifters with tappet shims
- New OEM crankshaft (naujas originalus alkuninis velenas)
- Big aluminium radiator with electric fans and Revotec controller
- Nismo engine mounts
- Samco Sport silicone couplings
- GroundZerO mandrel bent 2.5'' exhaust system (using custom 3" SS muffler)
- big high efficiency Hybrid front mount intercooler
- oil cooler kit with Mocal sandwich plate and custom teflon hoses
- Greddy radiator cooling panel
- Apex performance oil catch tank
- Greddy oil catch tank
- K&N oil catch tank filter
- Greddy 750 cc injectors
- Walbro 255 lph fuel pump
- Greddy Iridium plugs
- stand alone ECU
- Greddy Profec B-spec II boost controller
- Turbosevis BOV
- Design engineering turbo insulation kit
- CASTROL RS engine oil
Transmision:
- Refurbished gearbox (twice)
- KAAZ 1.5 way LSD
- Clutch Net Racing 4 Button "E-Z Lock Pro" Sprung Hub Clutch Disc (Nippon Clutch Clutch Cover)
- Nismo gearbox mount
Suspension:
- TEIN coilovers
- TEIN adjustable upper mounts
- Apex performance front strut bar
- Apex performance rear strut bar
- Apex performance front adjustable lower brace
- Apex performance rear adjustable lower brace
- Powerflex bushings
- Godspeed front anti roll bar
- Godspeed rear anti roll bar
- Driftworks Ultimate Carbon/Alloy adjustable tension rods
- SECTION fender braces
- Energy suspension steering rack bushes
- Apex performance rear toe arms
- Apex performance rear upper camber arms
- Apex performance rear traction arms
- Apex performance stainless steering disk
Brakes:
- S14a front brake calipers with BMW M3 Zimmerman brake rotors and Ferodo DS2500 pads
- Brembo drilled Z32 rear brake rotors with R33 brake calipers and HAWK HP+pads
- Z32 brake master cylinder
- GOODRIDGE brakes braided hoses
- Motul RBF 660 brake fluid
Interior:
- Apex'i boost gauge
- Ksport 6 point harnesses
- Nardi steering wheel
- K-sport quick release hub
- Ksport bucket seats on Apex performance rails
- custom C pillar bar
Exterior:
- 17'' OZ F1 wheels (front/rear tyres: Good Year F1 GS-D3)
- "Sleepy eyes"
- UNDERGROUND graphics
- Kouki rear tail lights
- Clear crystal headlights
Coming:
- Carbon fiber body parts
- Lexan screens
- Ikeya formula S14 tie rods
Diskusija apie S13/14 stabdziu upgrade'a naudojant m3 diskus perkelta cia.
foto AIRBOG savo s13 neturi?
turiu omeny latest :wink:
MilkMan
Post by MilkMan »
WOW :shock: Kokios firmos stand alone'as įdėtas pas tave?
Jauchiu LINK :)
o kuom jis blogas, kad taip sarkastiskai apie ji atsiliepi? Ar as blogai suprantu?
As planuoju DLinka det :roll:
Airbog
Post by Airbog »
romkasponka wrote:Jauchiu LINK :)
Blogai jauti. :wink:
NISMO' wrote:foto AIRBOG savo s13 neturi?
Laukiu fotosesijos pas VAZz. :wink:
Bus koks AEM POS... :)
nrvz
Post by nrvz »
Haltech :twisted:
Carlos
Post by Carlos »
Haltech E11V2.Yes?No?
Airbog
Post by Airbog »
Yap.
Airbog
Post by Airbog »
romkasponka wrote: o kuom jis blogas, kad taip sarkastiskai apie ji atsiliepi? Ar as blogai suprantu?
Blogai mano pasakyma supratai. Man jis tiesiog netiko, todel pasirinktas kitas + dar rimtesnis daiktas.
Groozdas
Post by Groozdas »
Ar galiu apsviesti kodel jis 'geresnis' nei DLinkas?
Airbog
Post by Airbog »
Bandyk, jei tiksliai zinai.
nrvz
Post by nrvz »
Groozdas wrote: Ar galiu apsviesti kodel jis 'geresnis' nei DLinkas?
todel, kad "Dlinkas" (http://www.dlink.com/) negamina ECU, o visokius routerius, swicthus ir pan stuffa :D
