Project: MITSUBISHI Eclipse GSX arba "childhood dream-car"
1997 USDM MITSUBISHI Eclipse GSX 5MT
* Megan Racing coilovers
* RM Racing F+R AWD sway bars
* Megan Racing rear trailing arms
* Goodridge EVO brake lines
* EVO IX brembo F+R brakes
* EVO IX ENKEI R17x8 ET38 rims
* Yokohama ADVAN A-046 235/45R17
> VISION forged anodized nuts M12x1.5
* Daikin Clutch slave cylinder
* Techna-Fit clutch line
* Shifter cable stiffeners bushing kit
* Symborski shifter kit
* Megan Racing short shifter
> Sparco "GRIP" pedals
* RECARO EVO IV seats
* 2 x 10" Maradyne high performance fan reversible S-blade
* Koyo radiator & Samco hoses
* APEX'i Power intake kit
* Zaklee clear cam gear cover
> Gates Racing timing & balance belts
> Gates accessories belts
* Magnecor 10mm ignition wires
* OEM fuel filter
* 6AN SS "fuel feed" kit
> 6AN SS "fuel return" kit
> Aeromotive Compact FPR & pressure gauge
* Walbro 255lph fuel pump with install kit
> EVO 560cc fuel injectors
> NGK BPR7ES ignition plugs
> EVO custom flashed ECU & Tactrix Openport 2.0
* Lotek double pillar gauge pod
* Prosport Premium boost gauge
* Prosport Premium EGT gauge
* HKS Turbo Timer Type-1
* EUDM front headlights
* EUDM rear lights
* EVO IX smoked side markers
? Carbon-fiber OEM style hood
> Punishment Racing atmosphere vented O2 housing
> Megan Racing 3" downpipe
* Megan Racing 3" catback
~ FMIC & piping
~ = ieskau
> = turiu
* = sudeta
? = nezinau
http://s103.photobucket.com/albums/m142 ... ANSFORMER/
* OEM fuel filter
* EUDM rear lights
~ FMIC & piping
~ = ieskau
> = turiu
* = sudeta
? = nezinau
Re: Project: MITSUBISHI Eclipse GSX arba "childhood dream-car"
Turetu geras buti KPIECAS
Beje, po visu vaziuokles modu, iki kol dar nepriesi iki "strokerio", nezadi kazka su kuro valdymu, turbina daryt, jei jau seks FMIC ir 3' ismetimas?
P.S. Kurio EVO stabdziai?
EVO VIII GSR SSL (sold)
EVO X MR
EVO X MR
Tie Walbro ir FPR tai cia smulkmenos, jeigu reiks vadinasi reiks isidet kartu su kitais dalykais...Mitsu wrote:...nezadi kazka su kuro valdymu, turbina daryt, jei jau seks FMIC ir 3' ismetimas?
Turiu EVO8 ir EVO9 komlektus, uzdet reiks tuos kurie geriau islaikyti, o kita rebuild'inti ir paskui apkeisti.Kurio EVO stabdziai?
coiloverius is statu siunteis? ar sitam zemyne radai
Mitsubishi Eclipse GSX 1993 - now you see me, now you don`t
Coiloveriai? Eclipse'ui 2G? Musu KAIME? Juokus megsti?Riebus wrote:...ar sitam zemyne radai
zlodejau kiek tu situ mitsu turi , ar tas baltas pas vyta ne tavo ??
Na yra dar vienas, bet ten visaaai kita istorija...
http://www.youtube.com/watch?v=riFNEdrKVpc
na nzn dabar vienam daviau uzklausima nes pas ji jau esu H&R pirkes amortikus tai sake gali ir koilus parvest bei turi ir TEIN tai ziuresim kokios kainos gal zymiai pigiau nei is statu siustisZLODEY wrote:Coiloveriai? Eclipse'ui 2G? Musu KAIME? Juokus megsti?Riebus wrote:...ar sitam zemyne radai
Na bet irgi "veza" ir gal net is tos pacios amerikos?
Siaip-netaip gavosi nuvalyti gerai parudyjusius EVO IX stabdziu diskus... ir dabar galvoju ar nudazyti "kepures" juodai ir jeigu taip tai kokiu budu geriausiai kad gerai laikytu
ar verta dazyti?
Volvo S80 2.5 TDI 1999
Na pas mane STi gamikliskai nudazyta ir labai gerai, tokiu nesamoniu su rudim nepamatysi...DeeDee wrote:ar verta dazyti?
Pagaliau atsilus orams per pora vakaru isejo padaryti viena is pirmu plano punktu Masina atvaziavo is Californijos tai gavosi kad su coil'ais ji pakilo, o ne nusileidoZLODEY wrote: * Megan Racing coilovers
Sekantis zingsnis = ratai nuo EVO9 ir geometrija, nes pakelus vaziuokle bug'as nedingo... t.y. daug issukus vaira jeigu jo atgal nepasukti truputeli, jis automatiskai negrizta. Tikiuosi kad vaziuokles geometrija isspres sita problema.
Na ir jeigu bus daugiau laiko ir gero oro tai judesim toliau, reikia deti brembo stabdzius, bet pries tai dar nemazai pavargti su elektrika del f@cking EU atitikties sertifikato
EVO9 ratai, ofsetas idealus...ZLODEY wrote: * EVO IX ENKEI R17x8 ET38 rims
- side view
- side by side.jpg (59.86 KiB) Viewed 19393 times
- 38ET
- EVO9 wheels.jpg (54.99 KiB) Viewed 19388 times
Turiu toki klausima... Kazkaip neiskarto pastebejau kad EVO9 ratu skyles nera konusines patogesniam centravimui. Gal kam teko susidurt kur galima butu perdaryti?
ZLODEY wrote: Turiu toki klausima... Kazkaip neiskarto pastebejau kad EVO9 ratu skyles nera konusines patogesniam centravimui. Gal kam teko susidurt kur galima butu perdaryti?
ant stock evo verzliu yra centravimas
Teisingai, bet butu daug patogiau tureti vieno standarto centravima ant savo masinu (ir varztai vienodi jau yra) + centravimas tikrai nebus pro sali jeigu dedi ratlankius ant masinos su kitu CenterBore ir centravimo ziedu nera...
O ziedai ne paprasciau? Pigiau?
Tokiems ratams teisingai uzsukt reikia specialiai stai tokiu verzliu...
- Original EVO wheels use unusual lug nuts with a built-in washer flange...
- OEM EVO lug nuts.jpg (34.48 KiB) Viewed 15635 times
Idejau A'PEXi oro filtra ir teisinga begiu perjungimo komplekta. Va dabar tai begiai persijungia kaip reikia, o ne kaip anksciau "ant snargliu"
Toliau ardom salona ir ruosiames atiduot kebulistams aptvarkyti isore...
- air intake.jpg (52.55 KiB) Viewed 14895 times
- short shifter.jpg (71.53 KiB) Viewed 14899 times
- nepatogu, bet ka daryti :|
- 01.jpg (42.66 KiB) Viewed 14698 times
- RMR swaybar 20mm
- 04.jpg (73.23 KiB) Viewed 14699 times
- guoliai vietoj gumu
- 05.jpg (71.9 KiB) Viewed 14701 times
Blogai kad neuzteko ~2mm skylems is katalizatoriaus > mid-pipe perejimas, bet tikiuosi antradieni kas nors pragrez ant stakliu. Bakelis siaip didelis, storas, bet man kazkaip nepatinka kaip atrodo sitas "soninis" JDM style, reiks turbut kada perdaryti "tiesiai"...ZLODEY wrote: > Megan Racing 3" catback
- MR catback VS stock...
- 02.jpg (54.7 KiB) Viewed 14694 times
- JDM style, bet man nepatinka kaip atrodo :/
- 03.jpg (45.7 KiB) Viewed 14670 times
- nauji "siurprizai" :(
- sudas.jpg (61.69 KiB) Viewed 14702 times
Dar yra pora klausimeliu, patarkit kas zino pls.
a) Kur ir kokia "smazke" nupirkti stabilizatoriaus sailentblokus sutepti (nebuvo komplekte kazkodel tai)?
b) Kas nors pas mus priekiauja atskirai guminem apsaugom guoliams, kaip buna ant visu sarnyru?
Stabilizatoriu traukes buvo komplekte ar pirkai atskirai?
Kazkaip niekur nemaciau kad dar ir traukutes detu. O ir niekas nesako kad jas reikia keist. Desiu OEM tik gal naujas... jeigu surasiu kur nes@dinus parduodaAirbog wrote:Stabilizatoriu traukes buvo komplekte ar pirkai atskirai?
