T28 banjo bolt tepalo skyle
Ar reikalingas tepalo restriktorius garrett t28 turbinai ir jei taip kokip diametro turetu buti skyle.
Konkreciau turbina:
14411-69f00
466541-7001
Konkreciau turbina:
14411-69f00
466541-7001
Re: T28 banjo bolt tepalo skyle
jeigu BB tai reikia2105 wrote:Ar reikalingas tepalo restriktorius garrett t28 turbinai ir jei taip kokip diametro turetu buti skyle.
Konkreciau turbina:
14411-69f00
466541-7001
from Garrett FAQ:
Q. Does my turbo require an oil restrictor?
A. Oil requirements depend on the turbo's bearing system type. Garrett has two types of bearing systems; traditional journal bearing; and ball bearing. The journal bearing system in a turbo functions very similarly to the rod or crank bearings in an engine. These bearings require enough oil pressure to keep the components separated by a hydrodynamic film. If the oil pressure is too low, the metal components will come in contact causing premature wear and ultimately failure. If the oil pressure is too high, leakage may occur from the turbocharger seals. With that as background, an oil restrictor is generally not needed for a journal-bearing turbocharger except for those applications with oil-pressure-induced seal leakage. Remember to address all other potential causes of leakage first (e.g., inadequate/improper oil drain out of the turbocharger, excessive crankcase pressure, turbocharger past its useful service life, etc.) and use a restrictor as a last resort. Garrett distributors can tell you the recommended range of acceptable oil pressures for your particular turbo. Restrictor size will always depend on how much oil pressure your engine is generating-there is no single restrictor size suited for all engines. Ball-bearing turbochargers can benefit from the addition of an oil restrictor, as most engines deliver more pressure than a ball bearing turbo requires. The benefit is seen in improved boost response due to less windage of oil in the bearing. In addition, lower oil flow further reduces the risk of oil leakage compared to journal-bearing turbochargers. Oil pressure entering a ball-bearing turbocharger needs to be between 40 psi and 45 psi at the maximum engine operating speed. For many common passenger vehicle engines, this generally translates into a restrictor with a minimum of 0.040" diameter orifice upstream of the oil inlet on the turbocharger center section. Again, it is imperative that the restrictor be sized according to the oil pressure characteristics of the engine to which the turbo is attached. Always verify that the appropriate oil pressure is reaching the turbo. The use of an oil restrictor can (but not always) help ensure that you have the proper oil flow/pressure entering the turbocharger, as well as extract the maximum performance.
69F00 yra S14, paprasta journal bearing. standarte jie neturi jokių restriktorių.
tai kad man rodos turi. neatsimenu kur traukiau info, bet paciam bloke lygtais yraard wrote:69F00 yra S14, paprasta journal bearing. standarte jie neturi jokių restriktorių.
Tai kad lyg ir paciam banjo bolt'e yra restriktorius, t.y. skyle jau reikiamo diametro.. jei neklystu tai ivorinems turboms turetu but apie 1,6mm restriktorius, guolinems apie 0,9mm
Originalaus banjo bolt neturiu, todel ir klausiu kokia turi buti skyle.
Aš ant T28 įvorinės turbinos irgi dariau 1,6.
Aero
B13 SR20DE +Turbo
N16 2.2Di +stage2
B13 SR20DE +Turbo
N16 2.2Di +stage2
man butent skandino ivorine turba kaip kad raso Garret info,padarius 1.6 restriktoriu viskas issisprende
Nubėgimas liaunas buvo gal? pas mane pamenu jokio restriktoriaus nebuvo 7mm skylė ir neskandindavo
o koks tepalo slegis pasilus masinai ir prie aukstu sukiu?pas mane maziau 2bar nenukrenta,o prie apkrovos 5-6 bar,druzokas savo BMW irgi be restriktoriaus,bet pas jy pasilus tik 1.2 bar,o prie apkrovu 4-5bar,taip kad skirtumas yra,o nubegimas 16AN tikrai manau ne per mazastomas636 wrote:Nubėgimas liaunas buvo gal? pas mane pamenu jokio restriktoriaus nebuvo 7mm skylė ir neskandindavo
Pas mane pašilus ir kažkur apie 1 bar laikydavosi
poto tik daėjo kad reik restriktoriaus
