replica ar originalas?
ACQ
Post by ACQ »
http://cgi.ebay.de/Pop-Blow-Off-Ventil- ... 1c09c1add5 pagal kaina sakyciau kad replica. O gal kas deveta turi pardavimui?
dolphin
Re: replica ar originalas?
Post by dolphin »
ACQ wrote:http://cgi.ebay.de/Pop-Blow-Off-Ventil- ... 1c09c1add5 pagal kaina sakyciau kad replica. O gal kas deveta turi pardavimui?
Kopija cia.
predi
Post by predi »
virsuje ir is galo turi buti isgraviruota HKS logotipas. Replica.
dolphin
Post by dolphin »
predi wrote:virsuje ir is galo turi buti isgraviruota HKS logotipas. Replica.
Tai pavadinime parasyta jau, kad kopija :)
ACQ
Post by ACQ »
aisku tada. ne vokietis esu. kvailas klausimas bet gal kas numanot koks bov modelis cia galetu buti http://www.youtube.com/watch?v=LA1a7swaA8A ? :)
ACQ wrote:aisku tada. ne vokietis esu. kvailas klausimas bet gal kas numanot koks bov modelis cia galetu buti http://www.youtube.com/watch?v=LA1a7swaA8A ? :)
Man rods, cia nera bovo isvis, cia surge'as girdisi :)
Man ir taip atrodo.
MikisV8
Post by MikisV8 »
"surge'as" O kas tai per daiktas?
edg
Post by edg »
MikisV8 wrote:"surge'as" O kas tai per daiktas?
tikiuosi moki naudotis google ten viską atrasi, ir nedaryk OT :idea:
Compressor surge is a condition caused, generally when a car with a turbo has a BOV that fails (or no BOV at all). When the driver slams the throttle plate shut, there is still compressed air in the charge pipe.
The turbo, however, has no power to spin, b/c theres no load on the motor ( ~0-5% TPS) so theres no exhaust.
This causes there to be more pressure on the turbocharger to backspin than spin in a forward direction.
I do not have *tons* of handson experience with it, but my take is that the turbo will "surge" making a kinda 'wub wub wub wub' sound (I've heard this) and go between spinning forward and backwards with the unequal pressures.
This causes massive amounts of turbo lag when you get back on the throttle and absolutely DESTROYS shaft style turbos
The other way surge can happen is if a compressor wheel (the cold side) is required to move a volume of air far beyond its capacity (outside the islands on a compressor map, past the surge lines). A similar phenomenon occours, except instead of backspinning the pressure generated by the turbo will oscillate. I have never personally had this occour, and can't say with any assuredness it makes noise. I would guess that it is not only noisy, but makes your boost gauge go psycho.
