HorsePowerAddict Motorsports
ViR2ality
Post by ViR2ality »
Sveiki gyvi,
Del vykdomu pagrindinio puslapio pertvarku bei restrukturizacijos sioje temoje stengsiuos pateikti kuo platesni esama produktu pasirinkima. Kolkas tai bus oficiali HPA Motorsports tema ;)
Coilovers:
Tein GSN66-DUSS1 Super Drift coil-overs s13/s14 - 1490usd + 140usd siuntimas = 3830lt (griebkit kol yra, turim tik 4 komplektus likusius, kitus tektu uzhsakinet)
Tein DSP04-KUSS2 SS coilovers s13/s14 - 1191usd + 140usd siuntimas = 3127lt
Tein DSP04-LUSS2 Basic coilovers s13/s14 - 886usd + 140usd siuntimas = 2411lt
Tein DSS64-8USS1 Super Racing coil-overs Impreza STI 2005+ 3299usd + 140usd siuntimas = 8080lt
Tein DSS66-KUSS2 SS coil-overs Impreza STI 2005+ 1266usd + 140usd siuntimas = 3304lt
Apex N1 Evolution Damper - DRIFT coil-overs S13 2261usd + 130usd siuntimas = 5642lt (vienintelis vienetas, ypatingai reti coilai, skirti JDM rinkai)
Apex N1 Type EXV Damper coil-vers S14 1240usd + 130usd siuntimas = 3233lt
Apex N1 Type EXV Damper coil-vers S2000 1191usd + 130usd siuntimas = 3118lt
Apex [[/b]b]N1 Type EXV Damper[/b] coil-vers is200/is300 1191usd + 130usd siuntimas = 3118lt
Apex N1 Type EXV Damper coil-vers EVO 8/9 1240usd + 130usd siuntimas = 3233lt
Pakaba:
Tein TRS01-N2010 Tie Rods s13(reikes s14 galu)/s14 79usd + 45usd = 291lt
KAAZ DBN2625 1.5way S13 LSD 975usd + 75usd siuntimas = 2468lt
KAAZ SAN2635 2way S13 LSD 975 + 75usd siuntimas = 2468lt
KAAZ DBN2645 1.5way S14 LSD 975usd + 75usd siuntimas = 2468lt
KAAZ SAN2645 2way S14 LSD 975 + 75usd siuntimas = 2468lt
Sankabos:
ACT SR20DET Modelis/Laikoma sukimo galia/Suspaudimo procentas lyginant su standartu
NS1-HDSS 362 50% 390usd + 100usd siuntimas = 1125lt
NS1-HDG6 * 463 50% 375usd + 100usd siuntimas = 1090lt (heavy duty diskatorius, 6lapeliai, spyruokles)
NS1-HDG4 * 463 50% 351usd + 100usd siuntimas = 1035lt (heavy duty diskatorius, 4lapeliai, spyruokles)
NS1-HDR6 * 463 50% 346usd + 100usd siuntimas = 1020lt (heavy duty diskatorius, 6lapeliai, be spyruokliu)
NS1-HDR4 * 463 50% 329usd + 100usd siuntimas = 990lt (heavy duty diskatorius, 4lapeliai, be spyruokliu)
NS1-XTSS 449 86% 442usd + 100usd siuntimas = 1242lt
NS1-XTG6 * 576 86% 427usd + 100usd siuntimas = 1200lt
NS1-XTG4 * 576 86% 402usd + 100usd siuntimas = 1155lt
NS1-XTR6 * 576 86% 398usd + 100usd siuntimas = 1145lt
NS1-XTR4 * 576 86% 382usd + 100usd siuntimas = 1100lt
Variklis:
Apex 814-N101 SR20DET bore=86mm T=0.8mm 194usd + 80usd siuntimas = 644lt
Apex 814-N102 SR20DET bore=86mm T=1.1mm 194usd + 80usd siuntimas = 644lt
Apex 814-N103 SR20DET bore=86mm T=1.5mm 194usd + 80usd siuntimas = 644lt
Apex 814-N104 SR20DET bore=86mm T=1.8mm 194usd + 80usd siuntimas = 644lt
Apex 814-N105 SR20DET bore=87mm T=0.8mm 194usd + 80usd siuntimas = 644lt
Apex 814-N106 SR20DET bore=87mm T=1.1mm 194usd + 80usd siuntimas = 644lt
Apex 814-N107 SR20DET bore=87mm T=1.5mm 194usd + 80usd siuntimas = 644lt
Apex 814-N108 SR20DET bore=87mm T=1.8mm 194usd + 80usd siuntimas = 644lt
Wiseco K556 serija visi ishmatavimai SR20DET 463usd + 70usd siuntimas = 1252lt
HKS 21004-AN001 SR20DET Stroker-kit 4169usd + siuntimas 110usd = 10055lt
HKS 24999-AM001 Tuning Timing Belt Lancer Evo VIII+ 173usd + 45usd siuntimas = 512lt
HKS 14007-AM003 High Flow Fuel Rail Lancer Evo VIII+ 427usd + 55usd siuntimas = 1132lt
ARP Connecting Rod Bolts for Nissan SR20 44.50usd + 60usd siuntimas = 246.62
Kuras:
Walbro 80usd + 75usd siuntimas = 364lt
Titan motorsports SR20DET Fuel Rail 189usd + 80usd siuntimas = 619lt
RC Engineering 155 cc,LOW RESISTANCE-2.5/3 OHMS $75 vnt + siuntimas
RC Engineering 195 cc,LOW RESISTANCE-2.5/3 OHMS $76 vnt + siuntimas
RC Engineering 210 cc,LOW RESISTANCE-2.5/3 OHMS $76 vnt + siuntimas
RC Engineering 225 cc,LOW RESISTANCE-2.5/3 OHMS $76 vnt + siuntimas
RC Engineering 250 cc,LOW RESISTANCE-2.5/3 OHMS $76 vnt + siuntimas
RC Engineering 270 cc,LOW RESISTANCE-2.5/3 OHMS $80 vnt + siuntimas
RC Engineering 320 cc,LOW RESISTANCE-2.5/3 OHMS $84 vnt + siuntimas
RC Engineering 370 cc,LOW RESISTANCE-2.5/3 OHMS $81 vnt + siuntimas
RC Engineering 550 cc,LOW RESISTANCE-2.5/3 OHMS $90 vnt + siuntimas
RC Engineering 750 cc,LOW RESISTANCE-2.5/3 OHMS $92 vnt + siuntimas
RC Engineering 1000 cc,LOW RESISTANCE-2.5/3 OHMS $92 vnt + siuntimas
RC Engineering 1600 cc,LOW RESISTANCE-2.5/3 OHMS $174 vnt + siuntimas
RC Engineering 160cc, HIGH RESISTANCE-12-16 OHMS $74 vnt + siuntimas
RC Engineering 195 cc, HIGH RESISTANCE-12-16 OHMS $76 vnt + siuntimas
RC Engineering 205 cc, HIGH RESISTANCE-12-16 OHMS $76 vnt + siuntimas
RC Engineering 210 cc, HIGH RESISTANCE-12-16 OHMS $76 vnt + siuntimas
RC Engineering 225 cc, HIGH RESISTANCE-12-16 OHMS $78 vnt + siuntimas
RC Engineering 240 cc, HIGH RESISTANCE-12-16 OHMS $78 vnt + siuntimas
RC Engineering 270 cc, HIGH RESISTANCE-12-16 OHMS $80 vnt + siuntimas
RC Engineering 310 cc, HIGH RESISTANCE-12-16 OHMS $81 vnt + siuntimas
RC Engineering 370 cc, HIGH RESISTANCE-12-16 OHMS $83 vnt + siuntimas
RC Engineering 440 cc, HIGH RESISTANCE-12-16 OHMS $83 vnt + siuntimas
RC Engineering 550 cc, HIGH RESISTANCE-12-16 OHMS $89 vnt + siuntimas
RC Engineering 650 cc, HIGH RESISTANCE-12-16 OHMS $89 vnt + siuntimas
RC Engineering 750 cc, HIGH RESISTANCE-12-16 OHMS $89 vnt + siuntimas
Ishmetimas:
RS*R High Flow catalyst 3' - 170usd + 75usd siuntimas = 575lt
Apex N1 76mm in 115mm out bakelis - 209usd + 84usd siuntimas = 692lt
Apex N1 60mm in 90mm out bakelis - 209usd + 84usd siuntimas = 692lt
Apex N1 ExTi 85mm in 115mm out bakelis - 420usd + 86usd siuntimas = 1194lt
Apex N1 GOLD 76mm in 115mm out bakelis - 218usd + 84usd siuntimas = 712lt
Apex WS2 76mm in 110mm out bakelis - 189usd + 84usd siuntimas = 644
Turbo:
Garrett Ball Bearing GT2560 300hp 750usd + 120usd siuntimas = 2044lt
Garrett Ball Bearing GT28RS 340hp 1120usd + 120usd siuntimas = 2914lt
Garrett Ball Bearing GT2871R 390hp 1231usd + 120usd siuntimas = 3174lt
Garrett Ball Bearing GT3071R 440hp 1260usd + 120usd siuntimas = 3243lt
Stabdzhiai:
Baer Extreme Plus 6pot 14' front brakes. 02+ STI 2745usd + 140usd siuntimas = 6808lt
Greddy GREX BRAKE SYSTEM s14 Front, Gold, 6 Piston, 330mm 2320usd + 140usd siuntimas = 5805lt
Greddy GREX BRAKE SYSTEM s14 Front, Gold, 4 Piston, 330mm 1872usd + 140usd siuntimas = 4748lt
Elektronika:
MoTeC M4 SEQ kompiuteris - 1830usd + 70usd siuntimas = 4451lt
AEM EMS 30-1602 SR20DET su visa pravodke 1899usd + 75usd siuntimas = 4639lt
APEX AFC NEO 365usd + 70usd siuntimas = 999lt
APEX Super AFC 360usd + 70usd siuntimas = 989lt
APEX AVC Type-R Boost Controller 505usd + 70usd siuntimas = 1325lt
APEX iMoni 202usd + 70usd siuntimas = 628lt
Greddy PROFEC B SPEC II 333usd + 70usd siuntimas = 943lt
Greddy E-MANAGE ULTIMATE 535usd + 80usd siuntimas = 1415lt
Greddy E-MANAGE (basic unit) 304usd + 80usd siuntimas = 884lt
Greddy PROFEC E-01 555usd + 75usd siuntimas = 1450lt
Greddy PROFEC TYPE S 333usd + 70usd siuntimas = 943lt
Greddy SPEED CUT CONTROLLER 76usd + 75usd siuntimas = 336lt
HKS GCC (Graphic Control Computer) 525usd + 75usd siuntimas = 1380lt
HKS AIC III Si (Additional Injector Controller) 715usd + 75usd siuntimas = 1817lt
HKS AFR (Air Fuel Ratio Regulator) 119usd + 75usd siuntimas = 446lt
TurboXS DTEC Boost Controller Pro 495usd + 75usd siuntimas = 1310lt
TurboXS DTEC Fuel Computer 338usd + 75usd siuntimas = 950lt
TurboXS DTEC Fuel Computer/Boost Controller Pro 628usd + 80usd siuntimas = 1628lt
Ausinimas:
PWR PWR1445 aliumininis radiatorius s13/s14 (SR20DET) 418usd + 140usd siuntimas = 1316lt
PWR aliumininis radiatorius Impreza STI 04+ 442usd + 140usd siuntimas = 1373lt
Fluidine 92-99 BMW E36 6Cyl. Aluminum Radiator 475usd + 140usd siuntimas = 1452lt
Fluidine 95-98 Nissan 240SX-SR20 Silvia aluminum radiator 425usd + 140usd siuntimas = 1334lt
Blitz COOLING PERFORMERS (Upper Radiator Hose w/ Temp. Port) s14 103usd + 78usd siuntimas = 416lt
Blitz OIL COOLER KIT (Remote Oil Filter Relocator Incl.) 833usd + 80usd siuntimas = 2099lt
Veleneliai:
Brian Crower Stage 3 s14 komplektas in/ex BC0206 – 300.00usd + 92usd siuntimas = 925lt
Brian Crower Stage 2 s14 komplektas in/ex BC0205 – 300.00usd + 92usd siuntimas = 925lt
Brian Crower Stage 2 boostB18C/B16A/B17A komplektas in/ex BC0011 – 429.00usd + 92usd siuntimas = 1230lt
Brian Crower Stage 2 Normally Aspirated B18C/B16A/B17A komplektas in/ex BC0012 – 429.00usd + 92usd siuntimas = 1230lt
Brian Crower Stage 3 Normally Aspirated B18C/B16A/B17A komplektas in/ex BC0013 – 429.00usd + 92usd siuntimas = 1230lt
Brian Crower Stage 2 boost B18A/B18B/B20B komplektas in/ex BC0021 – 309.00usd + 92usd siuntimas = 946lt
Brian Crower Stage 2 Normally Aspirated B18A/B18B/B20B komplektas in/ex BC0022 – 309.00usd + 92usd siuntimas = 946lt
Blow-Off Valves:
HKS SSQV - 202usd + 80usd siuntimas = 655lt
HKS Racing Bypass Valve 220usd + 80usd siuntimas = 699lt
HKS Super SQV Racing Single Valve 317usd + 80 siuntimas = 925lt
Greddy Type RS 188usd + 80usd siuntimas = 625lt
Greddy TYPE R std 205usd + 80usd siuntimas = 660lt
Greddy TYPE R Stiff Spring 205usd + 80usd siuntimas = 660lt
Apex'i Spec II 139usd + 80usd siuntimas = 512lt
Blitz Blow-Off Valve DD 184usd + 80usd siuntimas = 615lt
TurboXS Blow Off Valve Type S 125usd + 80usd siuntimas = 480lt
TurboXS Blow Off Valve Type H 173usd + 80usd siuntimas = 590lt
TurboXS Blow Off Valve Type H-RFL 181usd + 80usd siuntimas = 608lt
TurboXS Racing Bypass Valve Type H34 181usd + 80usd siuntimas = 608lt
TurboXS RRV Type H Reversible 181usd + 80usd siuntimas = 608lt
TurboXS Racing Bypass Valve Type 25 159usd + 80usd siuntimas = 556lt
TIAL Blow Off Valve 50mm 202usd + 80usd siuntimas = 657lt
Turbonetics Blowoff Valve, Street/Strip 95usd + 80usd siuntimas = 410lt
Saugumo iranga:
Mazworx S13 Harness Bar 389usd + 110usd siuntimas = 1153lt
Mazworx s13 Drift Roll Cage 1239usd + 200usd siuntimas = 3300lt
Titan motorsports S13/S14 Line Lock Kit 229usd + 95usd siuntimas = 745lt
Kreiptis PM & e-mail k.valius@bpg.lt
Supra MKIII coming soon :)
Airbog
Re: Parduodu: Pavasario ishsipardavimas/sandelio valymas
Post by Airbog »
Domina tie rod'ai. Komplekte turetu buti ne tik traukes, bet ir antgaliai (speju). Cia 240sx ar normaliam japonishkam/Euro RS13 su CA varikliu?
ViR2ality
Post by ViR2ality »
ne, antgaliai papildomai 80usd. Pagal kataloga tinka visiem S13 ;)
ViR2ality
Post by ViR2ality »
papildytas sarashas Apex'i gaminiais ;)
Bei parduodam uzhsakomus tik pagal specialu uzhsakyma ish JP Apex N1 Evolution Damper - DRIFT coilus skirtus s13. Sandelyje vienintelis kit'as - kas greitesnis to ir bus ;)
Airbog
Post by Airbog »
ViR2ality wrote:ne, antgaliai papildomai 80usd. Pagal kataloga tinka visiem S13 ;)
Kada galetu buti LT?
Giedrasas
Post by Giedrasas »
Citata is http://www.frsport.com/Tein-TRS01-N2010 ... _1024.html:
Tein TRS01-N2010 Hard Inner Tie Rod S13 S14
Vehicle Applications
1989 - 1998 Nissan 180SX all trims - s13 needs Tein/S14 ends
1989 - 2002 Nissan 200SX (Non-US) all trims - s13 needs Tein/S14 ends
1989 - 1998 Nissan 240SX all trims - s13 needs Tein/S14 ends
1989 - 2002 Nissan Silvia all trims - s13 needs Tein/S14 ends
-S14-
ViR2ality
Post by ViR2ality »
Giedriaum, nesupratau ka norejai tuo pasakyti/parodyti? :)
Airbog: ~3-4savaites
Giedrasas
Post by Giedrasas »
Tiesiog is aprasymo supratau, kad S13-am galima OEM antgalius nuo S14 uzdeti ir nebutina pirkt is uzsienio :roll:
No offence, gal ir nusisnekejau :wink:
Is ten pat:
S13 will need to use with s14 oem or aftemarket
-S14-
Airbog
Post by Airbog »
ViR2ality wrote: Airbog: ~3-4savaites
Per ilgai.
Bet aciu.
ViR2ality
Post by ViR2ality »
dekui uzh pataisyma, 13tam antgaliai tikrai yra kito kodo, tik patys endai skiriasi pas s13 ir s14, sutvarkysiu, kad konkrechiau butu :)
ViR2ality
Post by ViR2ality »
atnaujinta, prie sarasho prideta:
ViR2ality wrote:atnaujinta, prie sarasho prideta:
kad BMW'ams uz tokia kaina butu :cry:
ViR2ality
Post by ViR2ality »
manau kanors panasaus galeciau pasiulyti ir bmw, koks pas pati variklis?
ViR2ality wrote:manau kanors panasaus galeciau pasiulyti ir bmw, koks pas pati variklis?
M42
daomina kazkas apie 290 laipsniu velenai, solid lifteriai nu ir spyruokles..
ViR2ality
Post by ViR2ality »
apsimelavau, deja shitam varikliui nieko neturiu ka pasiulyt is valvetrain...
McPie
Post by McPie »
viskas tik s13/s14
FC/FD nieka nera?
RX-7 13B TII restauruojamas
ViR2ality
Post by ViR2ality »
turim ir gan padoru pasirinkima, tik sandelyje ne viska jam rasi ir taip pat i puslapi tik labai mazha dalis visko sudeja kolkas. Kas konkrechiau domintu?
Del serverio sutrikimu laikinai puslapis neprieinamas. Todel laikinas puslapio adresas:
http://yhst-81983501212733.stores.yahoo.net/
ViR2ality
Post by ViR2ality »
http://www.hpaddict.com puslapis vel veikia ;)
Taip pat, pasirashyta sutartis su TRD, tad nuo shiol atstovausim ir Toyota Racing Development ;) Vykdomas pirminis uzhsakymas, jei kasnors kanors domintu - kreipkities, kolkas kainynu dar neturim, bet visus kodus ir pasirinkima galite rasti: http://trdparts.jp/english/top.html
Del kainu - i privata ;)
ViR2ality
Post by ViR2ality »
Sarasas papildytas BOV'ais:
Nors BOV'ai neieina i ishpardavima, bet yra paklausi preke, o puslapis pastaruoju metu strigineja tai idejau chia. Turim ir daugiau firmu bei platesni pasirinkima, chia tik pagrindiniai musu siulomi BOV. Del kitu - kreiptis asmenine zhinute ;)
ViR2ality
Post by ViR2ality »
Nuo siol keichiasi musu puslapio adresas ir visa eshopo sistema, turesim dar platesni gamintoju pasirinkima, bei naudotu JDM detaliu. Balandzhio gale\Geguzhes pradzhioje laukite stambiu pasikeitimu! ;)
Nors puslpais iki to laiko bus aktyviai kuriamas ir neprieinamas masems, tachiau veikla vykdysim taip pat kaip visada. Tad nepatogumu sie pasikeitimai nesukels ;)
Re: Shop: HorsePowerAddict Motorsports
Domina kainos:
TRD - Altezza SXE10:
41201-SE100
33030-SE100
Laikas per kiek atvezimas.
O turba garrett GT2871R tai seip kiek as visur ziuriu tai iki 460ag o ne iki 390 kaip ponaitis parases :)
seip tai ar galima pas jus rintis A/R: 0.64 arba .86 AR?
ir seip visokius kitus housingus.. ?
ViR2ality
Post by ViR2ality »
rashau pagal "amerikonishka" rashyma kur vyrauja whp tai pilnai gali but :)
Taip, galima rinktis A/R, bet shiuo metu T3 housingu joms neturim:
Garrett 430609-0230 T25 4-bolt .64 A/R
Garrett 430609-5231 T25 4-bolt .86 A/R
Doggy, del shitu TRD per ryt gausi PM, nes bendrauju tiesiai su JP.
ViR2ality
Post by ViR2ality »
Visi PM atsakyti, atleiskit uzh ilga savaitgalio tarpa :)
Pora nauju detaliu kuriu jau turim vietoj sandelyje ;)
Kai rasai kainas, cia galutines? Ar dar reikia prisisumuoti mokescius?
Skunk2 prekiaujat?
2 romka: http://www.swiatek-tuning.com.pl/walkisportowe.php#bmw ?
