Siūlau: Adaptronic ECU | Flex fuel; Dual maps; Antilag...
Posted: 15 Dec 2015, 17:45
Platinu Adaptronic kompiuterius Lietuvoje. Gal kiek negirdėta kompanija mūsų šalyje, tačiau puikiai užsirekomendavus užjūryje. Puikus support'as ir didelė bendruomenė forume padeda greitai ir efektyviai išspręsti kilusius klausimus.
Visa krūva mokomųjų vaizdo įrašų Adaptronic Youtube paskyroje:
https://www.youtube.com/user/AdaptronicECU
Keletas vertų paminėti funkcijų:
Built in 4-bar MAP sensor to eliminate airflow meter
VE tuning to simplify injector upgrades
Easy to use software
Plugs into factory wiring
Compatible with many third party dashes and devices
Full closed loop operation
Flex fuel capable
Launch control, antilag, flat shift and boost by gear all standard
Fully sequential injection and distributor type ignition (ignition can be upgraded to direct fire if required)
Spare 0-5V analogue input
One additional spare aux output
3 spare digital inputs
Spare temperature input
This ECU also supports all the functions of the 440 ECU, however for advanced functions such as traction control, additional wiring and/or sensors will be necessary:
Flex fuel function – fill it up with gas/petrol or any ethanol concentration
Adaptive fuel control (self tuning) – reduces dyno time
Traction control function
Serial input for wideband O2 sensors (we recommend the MTXL)
Serial output for communication with dashes and dataloggers (we recommend the Race Technology units)
Headphone port for listening to the knock sensor while tuning
Basic closed loop ignition control
Closed loop fuel, idle, boost, 2 x variable valve timing control
Dual maps
Kainos sekančios:
Plug&Play:
Mazda MX-5/Miata NA6 (89-93) - 1350 EUR
Mazda MX-5/Miata NA8 (93-98 Two Plug) - 1350 EUR
Mazda MX-5/Miata NA8C (3 Plug) - 1450EUR
Mazda MX-5/Miata NB8A ECU (99-2000) - 1450EUR
Mazda MX-5/Miata NB8B & NB8C ECU (01-05) - 1450EUR
Mazda Rx-7 Series 4 (87-88) - 1450EUR
Mazda RX-7 Series 5 (89-91) - 1450EUR
Mazda RX-7 Series 6 &7 (92-98) - 1450EUR
Mazda RX-7 Series 8 (99-02) - 1450EUR
Mazda RX-8 Series 1 (Piggyback) 03-08 - 1475 EUR
Mitsubishi CE Lancer / Mirage 1.5L - 1450EUR
Mitsubishi CE Lancer / Mirage 1.8L - 1350EUR
Mitsubishi Evo Lancer 4-8 - 1450EUR
Nissan S13 SR20DET (Redtop) - 1450EUR
Nissan S13 Type X SR20DET (Blacktop) - 1450EUR
Nissan S14 SR20DET (76 Pin) - 1450EUR
Nissan S14a SR20DET (64 Pin) - 1450EUR
Nissan S15 SR20DET (64 Pin) - 1450EUR
Nissan 240SX - 1450EUR
Nissan R32 RB20DET / RB26DETT (89-94) - 1450EUR
Nissan R33 RB25DET / RB26DETT (93-98) - 1450 EUR
Nissan R34 RB25DET (98-02) - 1450EUR
Nissan Z32 VG30DETT (89-96) - 1450EUR
Toyota 2JZ-GTE 6Speed e420d Basic w/ patch harness - 1230 EUR
Toyota 2JZ-GTE 6Speed e440d Basic w/ patch harness - 1650 EUR
Toyota MR2 SW20 (89-99) - 1450 EUR
Universalūs:
e420d Basic Select ECU - 920 EUR
440 Universal Select ECU - 1350 EUR
e1280s ECU with 2m Loom - 1920 EUR
Šiuo metu paleidinėjama nauja programinė įranga bei kuriamas naujas modulinis kompiuteris su WiFi ir begale kitų funkcijų.
Flex fuel capable
Dual maps
Kainos sekančios:
Plug&Play:
Universalūs:
