For sale:Mazda Coupe FE Turbo showoff car
More photos: https://www.facebook.com/rolandas.grima ... 308&type=3
Price 7000 euro
Tekstas angliskai, nes orientuojamasi y uzsienio pirkejus, bet manau issiverst ne beda
I speak English, Russian, Lithuanian
Selling it, cause moving other rotation, building drift car, so price is very hurtfull for me, cause i have invested way much more
MAZDA FE TURBO COUPE GT SHOWOFF PROJECT
Mazda 626 Coupe 2.0 16V FE-Dohc Turbo 1989 year
Modlist:
ENGINE
Engine 2.0l FE Dohc 16V turbocharged CR 9:1
MS1 V3 standalone engine management
FE5A cam gears, NGK Iridium 7 spark plugs, NGK ignition cables
1bar boost 288ag 295Nm (need one more DYNO, cause were made more adjustments), with some minor modifications.like a bit bigger turbo, can be reached 350ag point.
Custom intake and exhaust manifold
Walbro 255lph fuel pump
Fram heavy duty oil filter
30 micron Autobahn88 fuel filter
Uprated engine mounts
2.5“ exhaust system, with Janspeed carbon N1 double back mufflers
540cc EVO fuel injectors
TD05H turbo from STI with external 38mm wastegate and screampipe(with fire on rev limiter kick)
Tomei adjustable Fuel preasure regulator
Manual boost controler
80mm throtle body
Custom intercooler piping with 700x180x70 intercooler and Autobahn88 silicone couplers, T bolt clamps
18mm Oil catch system, HKS SSQV blow off valve
Braided fuel and oil hoses
Apexi intake system
Contitech heavy duty timing belt, new bearings, seals, other belts
Exedy oem clutch kit
Coolant and vacuum silicone hoses from SFS Performace
ZEX nitrous system, connected to cool down intercooler with CO2, but can be set as nitrous setup easily
LiquiMoly 10W60 GT oil
LiquiMoly 75W90 GT gear box oil, with RVS lubricants for stronger hold
5.1 brake and clutch fluid
INTERIOR
Digital cluster(very hard to find)
Mongoose EMS 1.7R pager alarm security system
Tinted windows with Lumar film
RX7 front seats with 4 point Sparco harness
Victor steering wheel, Sparco pedal covers
Zex nitrous bottle between seats
AEM replica gauge set of: 100mm RPM with shift light, 52mm boost, af ratio, fuel preasure, oil preasure and temp, water temp, egt, voltmeter gauges
Detonation led gauge
Custom leather interior
Blue neon interior lighting system
SUSPENSION
Custom made KYB adjustable hight gas struts
Fully remanufactured brake system, calipers, Kashayama brake pads, drilled front rotors
18“ Yokawa rims, ET40, 8J with 225x35 Dunlop Sport tyres
Front strut brace
EXTERIOR
All car was repainted with high quality Spies Hecker paint, silver color has very deep pearl
Lamdo door system
Undercar blue neon lighting system, wheel arches and engine lighting system
RS tuning Custom glassfiber bodykit, custom front lights with HID, fitted rear led lights from Mustang 1996, by remaking all back with glassfiber, wider glassfiber arches
STI style glassfiber rear spoiler
Custom made body decals, Fast and Furious Skyline decal skin
AUDIO and VIDEO SYSTEM
JVC KD-AVX2 head unit, Signat 7“ LCD monitor in center dash, 2x 5.5“ Alpine LCD monitors in front doors for showoff
Front component system Phase Evoliution CFS 165 16.5cm 120w RMS, center Signat mid speaker for DTS, JBL GTO 6x9 rear speakers 120w RMS for surround
RockfordFosgate P3D412 12“ double subwoofer system, with 25mm walls sealed box, 1000w RMS
2x high speed Monitor 1F capasitors
50mm2 positive and negative wires, later spliting to 30mm2 to amplifiers
PolkAudio DB551 coaxial speaker system on the trunk for showoff
7“ Signat LCD monitor for showoff on the trunk
15.4“ Signat LCD monitor in the trunk for showoff with electric lifting system
Signat Platinum spliter with voltmeter and ampermeter
Amplifiers:Hifonics ZXI 8006 4 channels amplifier for front and back speaker system
RockfordFosgate T1500-1BD 1 channel amplifier for subwoofer system
Clarion 2 channels amlifier for center speaker
Alpine 2 channel amplifier for trunk showoff speaker system
Trunk neon blue lighting system with led disco efect
All car has damping and vibro insulation setup
2 alternators installed for power feed, total power 160A with 100ah 960A Bosch Gel battery, Signat Platinum high power negative and positive connectors with voltmeter, poweroff switch 200A, RockfordFosgate RFCB100 100A circuit breaker
Car has lots of awords for EMMA sound quality and showoff
Maby i forgot something, so you ask-i answer
More photos https://www.facebook.com/rolandas.grima ... 08&type=3​
Re: For sale:Mazda Coupe FE Turbo showoff car
Kadangi yra sioks toks susidomejimas,kaina galima derint kazka iskomplektuojant
