Pilnas Sr swapa'as su vismom smulkmenom: 276hp 335Nm. @ 1.1 bar. T28 standart turbo + turbo elbow, Braided oil & water lines, Horsham developments nissan doughterboard v2-0 + stage 1 chip, NGK 7s' spark plugs, ACT Heavy Duty pressure plate; organic sprung disc Nismo oil cap, D1spec 1.3 bar rad cap 6000lt
kebulas, be aftermarket daliu, be 5 lug kit' o galiu duoti stnd amortizatorius 3900lt
Apexi power intake + hard pipe 150lt
Apexperformance type2 FMIC 550lt
Mantoni ver2 bov 150lt
HKS silent Hipower exhaust 700lt
Walbro 255LPH fuel pump 150lt
z32 fuel filter
Nismo engine mount
Interior, Electronics:
Trust/Grex shift knob 50lt rezervuota
Driftworks drift button 30lt rezervuota
Momo corse steering wheel 150lt rezervuota
KNB steering wheel hub 70lt
D2 racing quick realease 100lt rezervuota
Greddy profec B boost controller
R32 GTR front seats x2 800lt
Driftworks 4 point driver harness, homo 2013 250ltrezervuota
Pioneer DEH p6100r 45w*4 head unit
Front Speakers Kenwood kfc-1789ie, 220w peak, 4 ohm.
Rear Speakers Boston 160w peak, 40w nominal, 4 ohm.
Suspension, brakes:
Polyurethane exhaust hangers
Ksport coilovers 8/6 rate ( priekinis desinys koilas barska ) 1000lt
Adjustable tension rods 200lt rezervuota
Adjustable rear camber arms 200lt
Adjustable rear toe arms 200lt
Apex perfromance rear subframe lower brace 100lt
Steering lock spacers
Apex performance subframe locking collars 70lt
4.36:1 Ratio welded diff 400lt rezervuota
Front brakes: z32 aluminium 4pot caliper with bracket, Brembo aftermarket 324*30mm discs, Reddot drift pads 600lt rezervuota
Rear brakes: z32 aluminium 2pot caliper, Brembo aftermarket 296*18mm discs, drum Handbrake, new pads 400lt rezervuota
5lug kit' as 400lt rezervuota
Exterior:
AVS model 6 rims. 8j et35, 9j et30 1100lt
Despoilered
All arches rolled out
Custom black corners
