Apexi power intake + hard pipe
T28 standart turbo + turbo elbow
Braided oil & water lines
Apexperformance type2 FMIC
Mantoni ver2 bov
HKS silent Hipower exhaust
Horsham developments nissan doughterboard v2-0 + stage 1 chip
NGK 7s' spark plugs
ACT Heavy Duty pressure plate; organic sprung disc
Walbro 255LPH fuel pump
Nismo oil cap
D1spec 1.3 bar rad cap
Z32 fuel filter
Nismo engine mount
Interior, Electronics:
Trust/Grex shift knob
Driftworks drift button
Momo corse steering wheel
KNB steering wheel hub
D2 racing quick realease
Greddy profec B boost controller
R32 GTR front seats x2
Driftworks 4 point driver harness, homo 2013
Aircon
Pioneer DEH p6100r 45w*4 head unit
Front Speakers Kenwood kfc-1789ie, 220w peak, 4 ohm.
Rear Speakers Boston 160w peak, 40w nominal, 4 ohm.
Suspension, brakes:
Polyurethane exhaust hangers
Ksport coilovers 8/6 rate
Adjustable tension rods
Adjustable rear camber arms
Adjustable rear toe arms
Apex perfromance rear subframe lower brace
Steering lock spacers
Apex performance subframe locking collars
4.6:1 Ratio welded diff
Front brakes: z32 aluminium 4pot caliper with bracket, Brembo aftermarket 324*30mm discs, Reddot drift pads
Rear brakes: z32 aluminium 2pot caliper, Brembo aftermarket 296*18mm discs, drum Handbrake, new pads
Exterior:
AVS model 6 rims. 8j et35, 9j et30 (Federal 595, front 80%, rear 70%)
Despoilered
All arches rolled out
Custom black corners
276hp 335Nm. @ 1.1 bar.
Automobilio variklis ir greiciu deze yra idealios bukles, jokiu papildomu garsu, dirba monotoniskai. Kebulas reikalauja tvarkymo/perdazymo. Automobili rekomenduojama apziuret, isgirsti. Jaunuoliai be pinigu net negalvokit apie “linksma” test drive.
Daugiau informacijos telefonais:
+370656563vienas7 Linas
+370624290du8 Tomas
Kaina: 18 000LT (Derybos welcome)
Foto:
http://www.autogidas.lt/skelbimai/nissa ... 04809.html
Klausimai telefonu arba PM, netersiam temos!!!
