Nissan 200SX S14 FAQ (DUK)
Postby tonic » 16 Jan 2006, 21:13
Techninia duomenys:
viewtopic.php?t=1010
SR20DET tune plan:
viewtopic.php?t=269
Re: Nissan 200SX S14 FAQ (DUK)
Postby ATMBOY » 30 Jul 2007, 19:43
SR20 ECU Error Codes:
TPS and/or Temp. Sensor interchange, anyone? let's not hijack this.
- this is general for 89-98 Nissan but most apply to the SR20 motor.
- to set car into diag. mode, with the key in the "ON" position, turn potentometer screw on ECU fully clockwise, then turn it fully counterclockwise. The LED on the ECU will begin to flash.
- first digit = LONG blink; second digit = SHORT blink (ex: 1... 1... 1... 1... then 1-1-1 equals 43 = TPS)
Error Codes Biatch
11 Crank Angle Sensor/Camshaft Position Sensor.
12 Air Flow Meter/Mass Air Flow Sensor.
13 Engine Coolant Temperature Sensor.
14 Vehicle Speed Sensor.
21 Ignition Signal.
22 Fuel Pump.
23 Idle Switch.
24 Throttle Valve Switch.
25 Idle Speed Control Valve.
28 Cooling Fan Circuit.
31 ECM.
32 EGR Function.
33 Heated Oxygen Sensor.
34 Knock Sensor.
35 Exhaust Gas Temperature Sensor.
36 EGR Control-Back Pressure Transducer.
37 Knock Sensor.
38 Right hand bank Closed Loop (B2).
41 Intake Air Temperature Sensor.
42 Fuel Temperature Sensor.
43 Throttle Position Sensor.
45 Injector Leak.
47 Crankshaft Position Sensor.
51 Injector Circuit.
53 Oxygen Sensor.
54 A/T Control.
55 No Malfunction.
63 No. 6 Cylinder Misfire.
64 No. 5 Cylinder Misfire.
65 No. 4 Cylinder Misfire.
66 No. 3 Cylinder Misfire.
67 No. 2 Cylinder Misfire.
68 No. 1 Cylinder Misfire.
71 Random Misfire.
72 TWC Function right hand bank.
73 TWC Function right hand bank.
76 Fuel Injection System Function right hand bank.
77 Rear Heated Oxygen Sensor Circuit.
82 Crankshaft Position Sensor.
84 A/T Diagnosis Communication Line.
85 VTC Solenoid Valve Circuit.
86 Fuel Injection System Function right hand bank.
87 Canister Control Solenoid Valve Circuit.
91 Front Heated Oxygen Sensor Heater Circuit right hand bank.
94 TCC Solenoid Valve.
95 Crankshaft Position Sensor.
98 Engine Coolant Temperature Sensor.
101 Front Heated Oxygen Sensor Heater Circuit right hand bank.
103 Park/Neutral Position Switch Circuit.
105 EGR and EGR Canister Control Solenoid Valve Circuit.
108 Canister Purge Control Valve Circuit.
Postby ard » 25 Feb 2011, 10:09
S14 rear bumpsteer'as
http://www.nissanroadracing.com/showthread.php?t=1652
During the testing it occured to me that the traction rod isn't the only thing that could affect bumpsteer. The RUCA also should have some affect as well. I'm running low rear camber, so I took another set of measurements with the RUCA shortened 1/4" to simulate a setup with more negative camber.
While getting the setup sorted with the Maximum Motorsports gauge, I ran into repeatability issues. Under compression, the car was lifting off the jackstands, and I was having to force the assembly down to measure droop. This was already with the coilover removed and the swaybar disconnected. Loosening all the joints (except alignment adjusters) fixed all of this, and the measurements were repeatable.
Traction rod lengths: 8.00", 8.25", 8.50"
RUCA lengths: 12.25" 12.50"
Postby ard » 22 Feb 2013, 00:50
JDM S14 - 23710-74F05 07/95 - 07/96 ECU pinout
http://www.eatsleepboost.lt/tech-info/n ... d-pinouts/
jeigu reikės PDF'o spausdinimui - manau galėsiu suorganizuot
Postby znd » 27 Dec 2013, 23:15
Gal kas galit pasidalinti manualu S14? Linkai is pirmo posto neveikia.
Postby ard » 29 Dec 2013, 17:17
Postby znd » 30 Dec 2013, 14:49
dekoju. 816 lapu :shock: :shock: :shock:
SR20 Roller Differences
Postby Eli » 11 Sep 2015, 10:31
Postby znd » 31 Mar 2016, 13:22
lyg ir veikiantis: s14 daliu schemos
http://www.neoriginal.ru/cat/nissan/gro ... 404_203001
Return to “Nissan”
